same in EA81 as EA81T
Does the EA81T use the same pistons as the EA81? I know some turbo cars use low compression pistons. Also does anyone know what the compression should be in an EA81T.
Kevin
1983 Subaru Brat Turbo
Kevin
Different pistons.Compression should be 110-120 psi depending on the cranking speed.
If you mean stastic compression, then the EA81T has 7.7:1 while the N/A Ea81 has 8.7:1.
