September 10, 200322 yr Guys Help me out here pls, If any of you say go, I'll get that half cut this instantly
September 10, 200322 yr DOOO EEEEEEEET!!! (i don't know what the cost in blood, sweat, and tears is, i just want to see it happen )
September 10, 200322 yr Might be tight between those frame rails.... stage 1 or stage 2 body? And what will you do for a tranny? Not gonna use the old one - won't handle the power. Best to use the AWD EJ tranny. Axles will have to be custom, as they will need the EJ inner joint, and probably need shortening. Lots of wireing to figure out, and shift linkage etc. BIG job, but certainly possible. GD
September 10, 200322 yr Author General Disorder, I'll be honest with you I already have that EJ 20 Turbo Quad Cam 32Valves (at least the seller claim it has 32Valve) Computer box and wiring still intact so is the gear box wiring. I have started the engine twice and engaged the transmission and let it running for 15 - 20 minutes each time First 10 minutes the engines is rough but it get smoother afterwards. So I guess basically the crucial wiring part would not worry me so much. It just that I hesitate to start removing the EA71 to put the EJ20T. People who earlier promised to help me with the project back out thinking of the mass its going to be. You said that is it possible...? yea O.K .... I'll be brave.
September 10, 200322 yr Author GeneralDisorder, Sorry for my ignorance but what is tranny, you said the old one would not be able to handle the power. Is it the mounting or the chasis it self
September 10, 200322 yr The transmisson (tranny) is the part that hooks up to the engine, and trasfers power to the wheels - you know - its the part you shift? Anyway, in your case, you have an EA71 transmission, which has a comletely different bell housing than an EJ20. There's NO way to put that engine in your car using the EA71 transmission. And if there were, it wouldn't handle the horse power of the EJ20 anyway, so it's no good trying to use it. You need an EJ20 transmission - maybe you already have one? Anyway - yeah, the swap can be done, but you will be fabricating a lot of parts for the job I would guess. Axles are going to be a major issue, as the hubs need the EA style axle, and the transmission needs the EJ style. So they need to be cut and welded together from the axles of the respective cars (and balanced too). once you figure out the mechanical side of things, the electrical stuff can be worked out. This is not a direct swap - expect to be welding / cutting / moving all kinds of stuff around to make it work. GD
September 11, 200322 yr tranny=gearbox hood=bonnet motor=engine tire=tyre english is one of the hardest languages to learn. too many of the same word means different things, or too many different words mean the same thing!
September 11, 200322 yr Its been done. The brat was lifted. Not much detail was provided but I had a picture of the under the hood stuff at one time.
September 12, 200322 yr Author shawn I need the pic that U mention. It will definately lift up the spirit. Regards Subzero
