September 11, 200322 yr i have a 88 turbo a/t wagon , i washed it with a power washer , when i got into the car the drivers seat really wet , any easy fix ? thanks :boohoo:
September 12, 200322 yr make sure all 4 drainage lines are cleaned out. Also with the roof open clean the area where the seal goes, cleaning the seals themselves helps too. Hopefully one or all of those things will work.
September 12, 200322 yr the drainage lines in front are accessed by the kick panels .. easily removed.. just below and in front of the front doors.
September 12, 200322 yr and the rear ones are back in the compartment where you access the taillight blubs
September 14, 200322 yr on my wagon i have to give it a little "push" as it closes up. this is what was up with jim's wagon. a little push fixed it
September 14, 200322 yr I also have to occasionally give mine a little push.. You said you washed your car with a power washer.. I have seen very few sunroofs that DON'T leak under direct pressure form a power washer
September 14, 200322 yr Author yes i had to give mine alittle push also , if not there will be a gap and water will come in, thanks to all
