BobBrumby Posted June 26, 2005 Share Posted June 26, 2005 For the first time on my 1990 burmby I pulled the dist cap and found a little 'black box' in there instead of the old contact breaker and has the two wires from the coil conected to it. The 'black box' doesnot have any contact with disty shaft and vacum advance rotates the plate the 'black box' is mounted on. Is this an electronic dizzy? Do i need a special cap and rotor for it? Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 26, 2005 Share Posted June 26, 2005 Yes, that is magnetic pickup loop. As one of the magnets on the shaft rotates by, a pulse is generated in the pickup loop and the signal is sent to the ECU so it can send a pulse to fire a plug. Some models had a couple different disty makes so it would be good to know what make your disty is. There have been mixups with the cap and rotors. Quote Link to comment Share on other sites More sharing options...
BobBrumby Posted June 26, 2005 Author Share Posted June 26, 2005 Has yellow and black wires running to dist. Quote Link to comment Share on other sites More sharing options...
