July 1, 200520 yr I came home for lunch and there was a branny-new rebuilt carb sitting there from Roo-Builders! Within 45 minutes, Tim got it in and it's running great! It comes up to temp and stays running, no stalls! Tim said he never even had to adjust anything... worked right off the git-go! Thanks Kerry, for an outstanding job! You rock! Actually, Mudrat79 made the final diagnosis of the problem I was having... he gave us a series of tests to be made and it failed them ALL... we talked and he described what to look and feel for. Thanks John! You rock! All my neighbors heard me today! And Skippy finally got to ride in it! She's not just a pretty face anymore! A major victory! Tim rocks!!
July 1, 200520 yr See Mary!! I told you not to give up on that thing!!! It had to be something simple. And you wanted to sell it...shame shame on you!!! Congrats btw..now you can take it more than 2 miles from the house! :banana:
July 1, 200520 yr Author Actually, Tim and Skippy drove up around the mall and started onto the highway... Tim heard a rubbing noise and decided against it... then it seems the noise left after a while... must have been rust from non-use. I started vacation today, I'll take it on my errands tomorrow and see if it's still happening. This is VERY, VERY exciting! I'm grinning so much my cheeks hurt!
July 1, 200520 yr hmmmm... a carb rebuild eh??? i probably need one... my carb doesn't seem to ever run quite right... how much did it cost?? who exactly did it for you??? i'm getting excited... or should i just weber it? hmmmm... webers cost oodles... rebuild sounds like it will get it running good...
July 1, 200520 yr Author hmmmm... a carb rebuild eh??? i probably need one... my carb doesn't seem to ever run quite right... how much did it cost?? who exactly did it for you??? i'm getting excited... or should i just weber it? hmmmm... webers cost oodles... rebuild sounds like it will get it running good... I got the new carb from Roo-Builders http://www.ccrengines.com/roobuilders/ They came highly recommended. The Hitachi carb was $195 plus shipping and a core charge. It came with all the screws and external doo-flickers (choke, throttle linkage, ADS) they were all rusty, loose and wiggly on mine. Just Plug 'n Play. As a note: I tried to get one through my local parts man and he told me that only 1 in 5 rebuilts that he gets in works... the other 4 fail and need to be returned. He deals with 2 other companies (Tomco & American?) and has no confidence in their products so he didn't want to order one for me... he's a great guy, honest and very knowledegable. He's anxious to hear the results of the Roo-Builders carb.
July 4, 200520 yr yeah tomco is crap! my friend a while back had a 70 ford f250 with the 390 in it and had replaced the carb with one from tomco and 3 carbs later he decided to put a brand new performance carb on cause of the issues he was having
July 5, 200520 yr Author The Brat runs great now, my 84 year-old mother wanted to go for a ride to the bank in it... she was loving it... even the part where the cabin suddenly filled with smoke and I pulled over, unhooked her seat belt and made her jump out. I figured out that the crankcase exhaust gasses are still routed to the undercarriage and then shifter boot isn't fastened in so it flaps opens up when I shift, letting the gasses into the cabin... the sun streaming in makes it look a lot worse than it is. LOL! After driving a whole 20 miles... it's now developed a strange non-rhythmic loud clicking (almost "snapping" noise). I have no clue what it could be... everything's new? Could be a bad rebuilt axle? Here we go again! Arrrggghhh!
July 6, 200520 yr After driving a whole 20 miles... it's now developed a strange non-rhythmic loud clicking (almost "snapping" noise). I have no clue what it could be... everything's new? Could be a bad rebuilt axle? Here we go again! Arrrggghhh! don't sweat the small stuff.... you've made it thus far!
July 6, 200520 yr The Brat runs great now, my 84 year-old mother wanted to go for a ride to the bank in it... she was loving it... even the part where the cabin suddenly filled with smoke and I pulled over, unhooked her seat belt and made her jump out. I figured out that the crankcase exhaust gasses are still routed to the undercarriage and then shifter boot isn't fastened in so it flaps opens up when I shift, letting the gasses into the cabin... the sun streaming in makes it look a lot worse than it is. LOL! After driving a whole 20 miles... it's now developed a strange non-rhythmic loud clicking (almost "snapping" noise). I have no clue what it could be... everything's new? Could be a bad rebuilt axle? Here we go again! Arrrggghhh! I have the same problem with the shifter boot,it works it's way loose. I thought it was because the brat is lifted. Anyone have a way to fix that?
July 6, 200520 yr Author I have the same problem with the shifter boot,it works it's way loose. I thought it was because the brat is lifted. Anyone have a way to fix that? There's a channel that runs around the "heel" that needs to be glued and then slid in so the metal rim of the opening is in the channel... I can't even get it in with no glue
July 7, 200520 yr Author shoegoo might work for you dave Does shoegoo stay wet while you try to slither it into place? Where does one get shoegoo?
July 7, 200520 yr yes it does and any walmart should have it it's one of those things that has many uses besides what it was designed to do lol
