fact or fiction?
a buddy of mine told me that he heard some where that you can install a spfi setup on an 85gl-wagon ea82 realy easy. just remove intake, all wiring and then the new intake and everythnig will pretty much plug right in is that true?
any help is good help
There's been a few guys who have done this conversion, you should be able to find everything you need to know by doing a search.
thanks, so far most of it had to do with a guise on the website but the guise is either not longer available or is jsut not working right now
i think you need the spfi distributor and it needs some kind of gear swapped onto it instead of the spfi one, it needs the carb'd one......theres a write-up about it in the USRM. ima look at it right now lol...
~Josh~
yeah i figured you would need those iteam but if you find anything else on it plz let me know i wanna get rid of my carb
Doable? Yes! Easy? Not unless you are good at wireing up EFI systems :)
I'm a little lazy since its kind of late here; check out the Search button, click on Advanced Search and look for spfi conversion
See what you can dig up there.
