no wcss for me oh wait its fixed now woot!
looks like i may have killed my megasquirt
by trying to fix a tps problem
i had the dam thing running and everything just had to get teh tps fixed.. i am so tired of working on things only to always have it go wrong
anyways to hot tired and depressed to try and fix it so screw it
Oh come on. You gotta go, I wanted to see your setup. I drove 5 hrs yesterday, so I could pick up a differential to put in my legacy to get it going before the show. :)
"If you hold it, they will come!"
Oddcomp, you should come anyways. I could still loan you a soob if you need one (just no rallyx or bashing it up, ok?).
I here that there will be beer...:drunk:
ya see.. its that whole being able to get there problem...
well looks like the box is not dead anyways
still s.o.l about tps
What about towing it...
Once you get it there you'd have all kinds of brain power to get it fixed :brow:
Get a rope! :grin:
tps problem as in ms thinks its wide open at closed throttle
and vice versa
found another tps not sure if it works or not waiting for the battery to charge incase thats part of my not staying running problem
and how do you propose i afford to tow it to wcss and back? :)
Yeah, push. Pull or drag.
Does MS use the TPS for anything other that transitional throttle enrichment? Should cruse fine, right?
Gary
...and how do you propose i afford to tow it to wcss and back? :)
Maybe the same way your wagon got from work to your house???
"If you can't walk, you crawl. When you can't crawl anymore, then your friends will carry you." - (TV series "Firefly")
i odn't mean this to sound smart assy but .. how do you propose i do that? stand on the freeway shoulder with a sign that sez wcss or bust? :)
tried reverse tps wires seems to do the same on the one tps
and pat.. thats a hell of a long ways to go just to drag my rx to the show..
i suspect my confusion has to do with being up for 28 or so hours yesterday 8 of wich at work and the rest arguing with the car
finally crashed at about 10 last night
Should be several people coming up from Portland, etc that could still be contacted. At least the convoys should be easy to spot.
and pat.. thats a hell of a long ways to go just to drag my rx to the show...
Its not an everyday event, and it would be a shame to miss it just because you couldn't quit futzing with your car right beforehand. :grin: (Like I am doing any better with my headless engine that is sitting outside on my engine stand for the last 4 days... :rolleyes: )
Do I WANT to drive the extra distance to haul your sorry behind (w/car) back up to WCSS7: No.
Will I do it if that is what it takes?: In a heartbeat. :)
BTW, which I-5 Exit-# are you near? I can't remember the number, but it isn't that far south of Exit 100-101 for Shelton.
well i got money to pay for gas
i can't seem to keep it running now.. so i am cornfused
it figures.. go outside to plug the tablet in to the ms to see if maybe the settings got corrupted from the tps being messed up
and the ppower plug breaks off the side of the case
chasing down what seems to be a lack of fuel problem now :<
I'm off to work in a few minutes; will check in again between 3-8am. Happy bug hunting!
well i just went on a nice cruise no hood scoop but i iced downt he intercooler with dry ice.. works well hehehe
apc is not hooked up so only seeing 5 psi actualy less now that i think about the wastegate line being connected before the intercooelr
it pulls nicely
scared a few mexicans with the ssqv
gonna put my wagon tires on it either tonight or in the morning not sure of the scoop
damm i am soo tired all day in the sun fighting with it
oh and i popped that pesky line thats under the intake.. thankfullly it the xt intake
i found a good tps in my pile o stuff
got my scoop on
gonna take a shower and head out and see if it wants to carry me to wcss
Oddcomp made it to the Show... running around trying to scare everybody with his unmuffled BOV(s)... the smaller one sounds like "nails on chalkboard" when it vents!
