Timing belt/Any other maint at 163k
I need to have my timing belt replaced on my 95 lsi wgn. Is there anything else I should have my mechanic do regarding seals, etc. when he has is off?
also do the water pump, cam seals, oil pump seals.
Its pretty much just parts costs since they already are doing work right there.
Hi,
Not that it is directly related but you may want to check the condition of the valve cover gaskets, looking for leaks. That way, you can DIY later if need be.
Regards,
Adnan
