August 30, 200520 yr Hay I need to find rims that will fit a 82 GL wagon that are 14 or 15''. I know they are hard to find because they are the wierd four lug 140 mm rim. I have herd that older Toyota truck rims would fit. Can anybody help me?
August 30, 200520 yr These are all the wheels that will fit your car. Your best bet would be to find some Peugeuot wheels. They come in 14" steels or 14"/15" alloys. Heres a link to the wheels page. Wheels page
August 30, 200520 yr peugeot has two models that will bolt right up: 404, and 505 in 14" and 15" respectively. many 6 bolt truck rims will work: rim being drilled with 2 additional holes for the 4 bolt pattern, or the hub/drum/rotor being drilled for additional studs. McBrat has a set of steel pug 14" he might ship to you.....
August 30, 200520 yr Pugs are the only cheap way to go if you don't want to convert or redrill. Allied Armament and a few Australian companies make oversized wheels though, but they're a lot more pricey than the $70 I paid for my Pugs.
