EA82 Water Pump Outlet
Has anyone tried to thread the outlet side of the water pump so a hose fitting could be used instead of the o-ring connection? Is there another alternative to the o-ring connection?
Thanks in advance,
Subpilot
What's wrong with the o-ring connection? I've never had a problem with it.
Thanks all. My application is in an airplane and I read a thread last week of someone having a leak at this connection. This has been a concern of mine for some time because a leak there could quickly drain my coolant. However, after reviewing my manuals again I see it is on the inlet side and I feel better about that. With the exception of the TD04 and intercooler I am trying to leave everything as stock as possible so I will continue with this connection as is and keep an eye out for any problems showing up on the board. Thanks again everyone.
Subpilot
