September 20, 200520 yr went to Sandlake Oregon last month had a great time the 215/75-15 snow tires with about 8 psi worked great, the 31" swampers were a little overkill , didnt need them, next year hope to have more Soobs out there to play with SJR
September 20, 200520 yr Looks like a blast! Those rear tires are great. Did you run a different size in the front than the rear???
September 20, 200520 yr the 215/75-15 snow tires with about 8 psi worked great, the 31" swampers were a little overkill It would appear they were. Doesn't matter out on the sand; drivetrain can slip and release pressure before binding up. How wide are those swampers? Backspacing on rim?
September 20, 200520 yr Author 31x13.5 SX super swampers actual measure about 29.5 not sure on the rim backspace
