Rear LSD?
Hi,
OK, this is gunna sound like a silly question!
How can I check if I have a rear LSD in my Leone?
Hayden
The diff should have a sticker on it either saying 'LSD' in big letters and a gear ratio, or just the gear ratio.
Another way if you have the rear of the car off the ground is to spin one tire. If the tire on the other spins the same way, you have an LSD. If the other tire spins the opposite way, it's an open-differential.
If it's anything like my cars, you'll have to clear a bunch of crud to read the sticker :lol:
edit: got beat to it :P
OK. I'll try the sticker but I use this car as a rally car and it may be wore off.
Are you sure the wheels we spin the same way if the back if lifted on the ground? Doesn't the diff only lock under load, otherwise it acts like a open-diff?
Hayden
Hayden
Yes, if they spin the same way, it is a LSD, if they spin opposite, it is an open diff.
