edjhover Posted October 7, 2005 Share Posted October 7, 2005 hello everybocy, this is my first post. I'm trying to replace my front pass side axle and it won,t come out. I have everything off inc. tie rod end, it seems the axle is too long to remove, any suggestions? thanks Link to comment Share on other sites More sharing options...
nipper Posted October 7, 2005 Share Posted October 7, 2005 describe "everything" nipper Link to comment Share on other sites More sharing options...
tcspeer Posted October 7, 2005 Share Posted October 7, 2005 Did you remove the pin? on the diff. side. also the whole hub and caliper needs to swing out of the way. Link to comment Share on other sites More sharing options...
edjhover Posted October 7, 2005 Author Share Posted October 7, 2005 hello everybocy, this is my first post. I'm trying to replace my front pass side axle and it won,t come out. I have everything off inc. tie rod end, it seems the axle is too long to remove, any suggestions? thanks i've removed the axle nut, and the diff side pin and tie rod end and the axle is loose at the hub and diff. but there doesn't seem to be enough room to slide the axle out Link to comment Share on other sites More sharing options...
edjhover Posted October 7, 2005 Author Share Posted October 7, 2005 yes , but there dosen't seem to be enough room to slide out the axle from the hub Did you remove the pin? on the diff. side. also the whole hub and caliper needs to swing out of the way. Link to comment Share on other sites More sharing options...
tcspeer Posted October 7, 2005 Share Posted October 7, 2005 Remove the ball joint pinch bolt and pry the ball joint out, you should then be able to swing it out of the way. Get the fork looking tool to seperate the ball joint. If I remember right the bolt must come out not just loosened. Link to comment Share on other sites More sharing options...
edjhover Posted October 7, 2005 Author Share Posted October 7, 2005 Remove the ball joint pinch bolt and pry the ball joint out, you should then be able to swing it out of the way. Get the fork looking tool to seperate the ball joint. If I remember right the bolt must come out not just loosened. I 'll give that a try, thank you fo r the advise. Link to comment Share on other sites More sharing options...
edjhover Posted October 8, 2005 Author Share Posted October 8, 2005 thank you for the help, I drop out the ball joint and sway bar, all went together well. putting the ball joint back in was tricky but i was able tto do it with the help af a floor jack. thanks again. Link to comment Share on other sites More sharing options...
