robb1 Posted October 25, 2005 Share Posted October 25, 2005 Hi all.have a 98 impreza outback sport. Noticed a yellow tinge to the back up light on one side. Maybe some water got in and rusted? Any way to access the inside of the tailight cover to clean it, besides just the bulb hole? Any comments appreciated!! Quote Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted October 25, 2005 Share Posted October 25, 2005 You might just want to try taking your tail light covers off of the car and clean them in some soapy water and them rinse them really well.Sometimes just needs some cleaning.Make sure you let them dry first before you put them on again. Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted October 25, 2005 Share Posted October 25, 2005 removing the tail lights from these cars is a right PAIN i would suggest, removing the bulbs. letting it air try check for leaks/seal if you can and maybe try to scrub the inside of the tail light with a baby bottle brush or some sort of very thin , very long brush. if you remove the tail light from the housing, you break the seal you break the seal, you run the risk of leaks when you reinstall the light. hopefully this helps. Jamie Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted October 25, 2005 Share Posted October 25, 2005 Any rust on the car yet? I lived there from 2002-2004, and when I left, my 95 Impreza had rust in all sorts of places! You have to love the "salt city" . The majority of the visible rust was on the rear wheel wells...moisture and salt got stuck between the rubber strip and the bottom of the fender, so check yours out! Just a heads up, I hope you solve the problem at hand though! Kevin Quote Link to comment Share on other sites More sharing options...
75subie Posted October 26, 2005 Share Posted October 26, 2005 couldn`t you take the whole light setup off and drill a drain hole in the bottom? Quote Link to comment Share on other sites More sharing options...
kevinsUBARU Posted October 26, 2005 Share Posted October 26, 2005 wouldn't moisture still get in? Quote Link to comment Share on other sites More sharing options...
robb1 Posted October 26, 2005 Author Share Posted October 26, 2005 Thanks to all that responded !!!!!!!! To:Kevin.... no rust yet.......only have 30,000 on it. To: Jamie......thanks,,thats exactly what i will try!!! Hope your all havin a great fall ! Rob Quote Link to comment Share on other sites More sharing options...
The Korean Posted October 26, 2005 Share Posted October 26, 2005 I've been told to use Subaru Brake Cleaner on the headlights to get the yellow tintage off of them... but that's for headlights... I'm sure it might work for the reverse lights. Quote Link to comment Share on other sites More sharing options...
