November 13, 200520 yr Greetings: My new 2005 Legacy 2.5 GT Power stirring fluid level was below the Cold Min mark. While trying to fill it up with Dexron III, my hand just slip and I overfill a bit higher than Cold MAX mark. I don't think this is going to be a big issue, isn't it? Any additional comment is greatly appreciated.
November 13, 200520 yr likely all that will happen is that some of the PS fluid will "foam" out... meaning it'll flow out the cap and get all over everything but that's about the most "damage" i can see occurring if you're worried about it... remove some of the fluid (with a baster or a siphon tube) Jamie
November 14, 200520 yr If it worrys use a turkey baster and take soem out...just make sure to buy a new turkey baster....
