kindablue Posted November 15, 2005 Share Posted November 15, 2005 Hey anybody have the weights of the alloy and steel wheels (rims)? Thanks Quote Link to comment Share on other sites More sharing options...
tunered Posted November 15, 2005 Share Posted November 15, 2005 Hey anybody have the weights of the alloy and steel wheels (rims)?Thanks what are you asking? Quote Link to comment Share on other sites More sharing options...
kindablue Posted November 15, 2005 Author Share Posted November 15, 2005 what are you asking?[/quoteI am asking what the weight of a Subaru wheel is. How much does a steel wheel (rim)weigh? How much does a alloy wheel (rim) weigh? Let's say 15 inch rims. Thanks again. Quote Link to comment Share on other sites More sharing options...
outback_97 Posted November 15, 2005 Share Posted November 15, 2005 http://wac.addr.com/auto/obs/wheels.html Try this, it has some info that might help. Steve Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted November 15, 2005 Share Posted November 15, 2005 16's i know for a fact... wrx 16" rims = 17lbs each Forester 16" steel wheels - 32lbs each Jamie Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 15, 2005 Share Posted November 15, 2005 what are you asking?[/quoteI am asking what the weight of a Subaru wheel is. How much does a steel wheel (rim)weigh? How much does a alloy wheel (rim) weigh? Let's say 15 inch rims. Thanks again. There are aftermarket wheels that fit soobs all the way down to under 9 lbs. IIRC. Stock wheel weights can sometimes be figured out by weighing the tire/wheel set and subtracting the tire's weight as listed by the manufacturer. For instance, my '06 WRX wheel/tires weigh about 43.5lbs according to the freight scale at work. The listed weight (at tirerack.com ) of the stock 215/45/17 RE-92s is 23 lbs leaving a wheel weight of approx. 20.5 lbs. I suspect that could be plus/minus 5% easily. What are you trying to accomplish? Quote Link to comment Share on other sites More sharing options...
Gnuman Posted November 16, 2005 Share Posted November 16, 2005 Most likely, he is trying to reduce his wheel weight. The weight of the wheel factors into how much power is needed to turn it. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 16, 2005 Share Posted November 16, 2005 Most likely, he is trying to reduce his wheel weight. The weight of the wheel factors into how much power is needed to turn it. It isn't clear however if he wants to purchase stock take-offs or aftermarket. Plus, ultra light wheels might be OK for the street or strip but not auto or rallyX. I dunno Quote Link to comment Share on other sites More sharing options...
AlpineRaven Posted November 16, 2005 Share Posted November 16, 2005 I recently weighted 16" 1999 Legacy GT2.5 mags, they were 7.5kgs/16.53lbs. Can't tell you how heavy 16" steelies would be. Cheers AP Quote Link to comment Share on other sites More sharing options...
