my car is shaking....
When I start my car t drive it in the first gear is shaking...what could be?
Thank you:)
Thank you:)
We need more info! Is the whole car shaking? Can you feel it more in the steering wheel, or pedals, or just general shaking? Does it vary with the speed of the car. Or going around turns. How about if you rev the engine in nuetral. It is an automatic or a manual? Any noises associated with it?
OK.
-engine is working fine in neutral(manual gear)
-is shaking when i start the car on the roa(in first gear-logical wright?) for 2-3 seconds until is start running......and is stop and is working fine.
-yes, whole car shaking
I think is a leak of power...but is only a gues.Is enough????
Thank you.
Hmmm. Sounds like a grabby clutch. I think this is usually from getting oil on the friction disk -- possibly from a leaking transmission seal, or main engine seal? Anyone else have ideas?
Try starting off from a dead stop in third gear. If you can do it smoothly without the car stalling your clutch is slipping.
nipper
nipper
I've tryed to start off from a dead stop in third and second gear and if I not accelerate engine over 2000-2500rpm.....is almost stop and car shaking verry bad.
So, my clutch need to be replaced or if I adjust him will be OK...I jus wonder...could be the clutch cable too tight.
Thank you so much.
Could also be caused by a brake that won't fully release, or is locked up. Try raising the wheels off the ground, and see if they will turn easily by hand, be sure to have tranny in neutral for the fronts.
Wheels are OK.
Thank you so much.
well the car should stall with a third gear start. You should be able to doa second gear satrt with no problem.
i am beginng to agree its oil on the clutch disc. with what information i have. Does it go away after the car warms up. Let it sit in your driveway running for 15 minutes then drive it?
nipper
