vick Posted November 18, 2005 Share Posted November 18, 2005 Hey everyone thanks to you I got my 2.2 running nicely now after the coil problem which was causing it to run rich, (wasn't firing on 1+2 once warm) the tailpipe was carbonned up pretty bad, well now I am thinking the turbo might also have a lot of carbon on it which I would like to remove. Any suggestions on how I could get the carbon off the blades without removing the Turbo, would a spray type cleaner or seafoam be safe? Thanks. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 18, 2005 Share Posted November 18, 2005 The carbon would only be on the turbine side. Just run some sea foam through. I wouldn't really worry about it though. Turbine temps get pretty high and cook stuff off. Quote Link to comment Share on other sites More sharing options...
tunered Posted November 18, 2005 Share Posted November 18, 2005 i dont think this would be carbon but might be called soot,a nice drive down the interstate would probbally do it. ed Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 18, 2005 Share Posted November 18, 2005 Is it possible to have an oil seal leak in the turbo? Quote Link to comment Share on other sites More sharing options...
Setright Posted November 18, 2005 Share Posted November 18, 2005 Texan, I believe the turbo uses a plain bearing, so wear will see this bearing leaking oil to both sides. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 18, 2005 Share Posted November 18, 2005 Yes it's possible that you can have an oil seal leakage. I'm not sure the type of oil seal that's in there though. Quote Link to comment Share on other sites More sharing options...
vick Posted November 18, 2005 Author Share Posted November 18, 2005 I don't think I have any oil leakage, just concerned about the Turbo blades having carbon on them and possibly throwing them out of balance. Plugs 3-4 had a lot of carbon on them, the muffler and tailpipe were black. Quote Link to comment Share on other sites More sharing options...
