November 18, 200520 yr The plastic epoxy that the knock sensor is cast in on my 2.2l legacy motor is craking. No codes indicating a malfunction have been set, so I'm wondering whether to replace it or not?
November 18, 200520 yr replace it before you get codes. Always easier to replace things on your terms then the cars. nipper
November 18, 200520 yr What colour is the connector? They revised the design of the sensor and changed the connector to white - old style is gray. Replace it if the connector is gray - nevermind whether it's cracked or not.
November 18, 200520 yr Ditto on the old style replacement. But yeah, if it's cracked, you should replace it.
November 18, 200520 yr What year did they change? I'm reading into the remarks that the grey version is inferior.
