Novakaine Posted November 28, 2005 Share Posted November 28, 2005 Hey all, So here is the situation. I recently replaced my rear hatch from one without the rear wiper to one with the rear wiper. I assumed that as soon as I hook up all the wires, the rear wiper would work, not the case though. Since all the wires were already there and there is a rear wiper control on the little black stick behind the steering wheel, I assumed i did not need to do anything else. I looked around for any relay or fuse that might need to be added, but i can't find anything like that. The only thing I saw was at the washer tank, fluid tbe needs to be hooked up, but even without that the arm should still work. Any ideas and any suggestions would be much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2005 Share Posted November 28, 2005 yup there is a relay, i dont where it is located, but there is one. nipper Quote Link to comment Share on other sites More sharing options...
Novakaine Posted November 28, 2005 Author Share Posted November 28, 2005 Awsome, is there anyway you could find out where the relay is or tell me what to look for? Thanks. I looked for a relay in the little black fuse box in under the hood near the battery and in the little fuse box by the driver left foot, and nothing seems missing. ANy ideas? yup there is a relay, i dont where it is located, but there is one. nipper Quote Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2005 Share Posted November 28, 2005 Awsome, is there anyway you could find out where the relay is or tell me what to look for? Thanks. I looked for a relay in the little black fuse box in under the hood near the battery and in the little fuse box by the driver left foot, and nothing seems missing. ANy ideas? not a clue, its a std electro mechanical realy, with 6 pins. i would suspect it to be under the dash wire codes LT GRN OR BLU/BLACK - TO PARK-RUN IN MOTOR BLU/WHIT OR GRN - TO MOTOR BLK/WHT OR GRN/RED TO COMBO SWITCH (should be a small wire) WHT/BLU WHT/BLU- FROM THE #2 FUSE WHT/BLU OR BLK/RED TO REAR WASHER PUMP FROM FUSE BOX LT GRN/BLK OR BLU BLACK FROM PUMP TO SWITCH. BLACK FROM SWITCH TO GROUND. Best thing it to try to traceit from the switch hope this helps nipper Quote Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2005 Share Posted November 28, 2005 http://www.ultimatesubaru.org/forum/showthread.php?t=47721 watch that thread .. it may help Quote Link to comment Share on other sites More sharing options...
