2000 Outback-clicking sound in frnt drvside suspension
I'm getting a clicking sound ONLY when I turn left and the car is cold. It sounds like a cv joint going bad. It sounds like it is coming from the front left tire area.
Any ideas.
Thank you to all that respond, John
Hmm I'm getting the same thing too.
However, I cannot find a tear in any of the two, left cv boots. Was yours internal. I mean, something wrong with the gears under the boots. What did you have replaced exactly? The boot or something else?
THanks, John
I second the CV/axel...
I replaced my front left one at about 120k. There was no sound, my mechanic noticed it was torn so i told him to replace it.
Avish
Hey John :drunk: How's it going?
Just to rule this out: Does the sound go away when you depress the brake pedal slightly? I had a loose brake pad that was making a clicking sound when turning, I knew it was something in the brakes because as soon as I pressed the brake pedal, the contact with the rotor would stop the pad from knocking around and clicking. Worth a try just to rule that out.
Steve
