rweddy Posted January 2, 2006 Share Posted January 2, 2006 Can someone tell me what size the allen bolts are on the bottom of the oil pump? 96 2.2 legacy obw I need to get the correct size socket. Thanks Quote Link to comment Share on other sites More sharing options...
ccrinc Posted January 3, 2006 Share Posted January 3, 2006 They should be 14mm. However, you don't need to take those off at all. Just the back plate and the angled bolt on the side. Emily http://www.ccrengines.com Quote Link to comment Share on other sites More sharing options...
rweddy Posted January 3, 2006 Author Share Posted January 3, 2006 They should be 14mm. However, you don't need to take those off at all.Just the back plate and the angled bolt on the side. Emily http://www.ccrengines.com Thanks. I have already done the t-belt, changed the water pump, sealed up the oil pump but one of these bolts seems to be seeping a bit and do not have a wrench big enough. Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted January 3, 2006 Share Posted January 3, 2006 If you had a bunch of bolts and nuts lying around, you could make one to tighten the thing up. OR at the very least, you'd be able to figure out the size. Quote Link to comment Share on other sites More sharing options...
Andyjo Posted January 3, 2006 Share Posted January 3, 2006 I borrowed a 14mm tool from the local shop, i bet if you ask nicely they'll let you borrow/rent one Quote Link to comment Share on other sites More sharing options...
