January 10, 200620 yr a few pics of the at clutch pack, duty c sol and the crud in the valve seat. as you have already figured out: duty c off (retracted, no electricty) = 4wd locked duty c always on (extended, constant elec.) = fwd only duty c controled by tcu (variable on/off) = awd as needed when the duty c fails or the valve seat gets crud in it restricting the flow, you have torque bind.
January 11, 200620 yr Just a thought: Since this solenoid fails from time to time, why is it hidden inside the case? I would be very convinient to have it outside the case IMHO.
January 11, 200620 yr nice picks indeed, doesn't look hard at all? much easier than i thought. is there a new gasket that goes between the rear extension housing and the trans case when you reassemble?
January 11, 200620 yr Author nice picks indeed, doesn't look hard at all? much easier than i thought. is there a new gasket that goes between the rear extension housing and the trans case when you reassemble? there is a gasket betwen the trans and the this cover. my guy at the trans shop suggested that a silicone gasket would do the job. he charged 3.5 hours to install my used clutch pack, new gasket and 2 qts. fluid, all for $280. this sound like more time than described by someone here previously, but what the hell, the dealer wanted $1000. some one has described the r&r in a thread earlier, can't remember who. he said you could lower the trans slghtly, let it angle down, and do the job with out pulling the trans. in hind sight i should have priced and used a new solenoid. i don't know what they cost, but for 280 in labor it would be a good investment. i have limited experience, but it seems to me that the clutch it self is pretty tufff. but the valve seat and sol are the weak points. i'll be pissed if the used one fails in the next 100k miles. the one in my 95 2.2L went 167K mi. before reverse failed. john
