jetboy12 Posted January 18, 2006 Share Posted January 18, 2006 I just got the auto transmission in my 1994 Legacy AWD swapped out with a Japanese imported one (was going to do it myself but no time). When I got it back from a local transmision shop there's an issue with the speedometer/odometer not working. The mechanic said that the one he put in is "older" than a 94 and doesn't have the proper wiring to rig up to the computer. Is this a common problem on swapping Legacy transmissions or is he blowing smoke somewhere ? He mentioned rewiring to the ABS system wheel sensors. Any possible fixes, suggestions or advice on this would be helpful. Thanks ! Quote Link to comment Share on other sites More sharing options...
seattlelegacy Posted January 18, 2006 Share Posted January 18, 2006 I just got the auto transmission in my 1994 Legacy AWD swapped out with a Japanese imported one (was going to do it myself but no time). When I got it back from a local transmision shop there's an issue with the speedometer/odometer not working. The mechanic said that the one he put in is "older" than a 94 and doesn't have the proper wiring to rig up to the computer. Is this a common problem on swapping Legacy transmissions or is he blowing smoke somewhere ? He mentioned rewiring to the ABS system wheel sensors. Any possible fixes, suggestions or advice on this would be helpful. Thanks ! Whaaaa? I thought it was of the cable type. This doesn't sound right... Quote Link to comment Share on other sites More sharing options...
jetboy12 Posted January 18, 2006 Author Share Posted January 18, 2006 That's what I thought too. He mentioned that it was the same trannie as a Nissan and that they could splice a early 90's 4x4 Pathfinder harness into the ABS system wheel speed sensors (they did it before on an Impreza). Could they have broke something in the swap ? It shifts fine, just no speedo or odometer. Quote Link to comment Share on other sites More sharing options...
Chef Posted January 18, 2006 Share Posted January 18, 2006 Sounds like the wrong transmission sent to them. The 4EAT is a subaru tranny only I'm sure. That's what I thought too. He mentioned that it was the same trannie as a Nissan and that they could splice a early 90's 4x4 Pathfinder harness into the ABS system wheel speed sensors (they did it before on an Impreza). Could they have broke something in the swap ? It shifts fine, just no speedo or odometer. Quote Link to comment Share on other sites More sharing options...
jetboy12 Posted January 19, 2006 Author Share Posted January 19, 2006 Who knows, I think he was talking about the Impreza trannie, something about it fitting a Nissan 240. The trannie they put in was the same as mine (I bought it), just something about the speedo setup being different. I may take it to another shop and see if they can fix it. It seemed easy to me, take one trannie out put the same trannie in. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 20, 2006 Share Posted January 20, 2006 He's blown smoke up your arse. Where in texas are you? Quote Link to comment Share on other sites More sharing options...
jetboy12 Posted January 23, 2006 Author Share Posted January 23, 2006 I'm in San Antonio, So would I need to take it somewhere else and have the speedo hooked up ? Seems to shift fine, just no speedo/odometer. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 23, 2006 Share Posted January 23, 2006 i would look for the cable and verify if it is or is not there first. out of the top of the trans (just behind the motor) and also check behind the instrument cluster....get all twisted lying on the floor and have a flash light handy. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 24, 2006 Share Posted January 24, 2006 Yeah, there should be a spot on the front diff on the passenger side of the car, just behind the motor where the speedo cable base should go. It'll look like this http://www.main.experiencetherave.com:8080/subaru/images/speedocablebase.jpg The cable just goes down into that. Quote Link to comment Share on other sites More sharing options...
