February 7, 200620 yr Turbo coupe.84 ej22 mated to SVX trans should make for awsome milage and a skyhi top speed... anyway just a thought for some kicks
February 8, 200620 yr If it is going to spend it's life on the highway, you'll see a fuel savings. Around town, I think the lack of power from the EJ22 will burn more fuel pulling away from stop signs and lights???
February 8, 200620 yr keep in mind that the turbo coupe doesnt weigh too much, probably 1500 lbs less than an SVX, and with at LEAST 130 hp from a early legacy ecu and wiring, you shouldnt see too much of a drop in mileage. but tranny cooler and bigger exhaust are a must if you plan on getting the most from the motor and tranny combo. ~Josh~
February 8, 200620 yr Author my svx is somthing like 3000+lbs im going to make it a highway cruiser. these are the wheels im going to use. http://www.ultimatesubaru.org/80s/wheels2/wire-spoke-13-alloy.jpg they should look good on the turbo coupe. pluse ive got the only set around...
