Tranny Stub Broke out
My 1990 subaru layale had an impact on the front tire resulting in the axle pulling the tranny stub out of the auto tranny. What probably happened to my tranny and how do I diagnose this and how fixable is this problem. I have an excellent 5 speed which I can install if need be, a lot of work but I would love it to be a stick. Also, do the 2 types of trannies basically swap or are there dxrive shaft changes and such that need to be done, I will search more but so far havent found good posts, can anyone direct me to a few.
sounds like you had better start on that swap...
or find a new tranny.
-=Suberdave=-
Well - I think if you can't pound that puppy back in (some tranny's apparently you could slide-hammer those out, but others were bolted in from the inside?) then your are SOL.
As good a time as any for a 5 speed swap it sounds like.
Take a look at the stub that got "pulled" out and see if you can determine if it broke, or was just pulled free of the diff.
you would have to completely tear the tranny apart to the stub back in - it is attached with a C-clip in the front diff
swap the tranny
swap the tranny
Yeah - probably a cir-clip floating around in your tranny.... perhaps replacing it with a spring style clip would work... might want to try and get the old cir-clip out with a magnet if you can find it :rolleyes:
I'm thinking you should go with the 5 speed. Less potential issues later.
I've pulled those stubs out of a legacy tranny before. Another shop in town needed one and they said that they pounded it back in. Hell in a wrecked forrester that we made into a rally ride for around the shop, we used bigger spring rings or what ever they are called, cut them down and bent it to fix and pounded rear axles back into the diff. It seemed to work.
As far as the EA tranny, I'm not sure. There is one sitting at my shop that has the same problem. From looking at it, probably going to have to rebuild the front diff of the tranny, or replace the whole thing.
it will pop back in. there should ba a spring clip on the tranny end and just tap the stub back in
if the clip is missing it will still work
miles is right, don't get anxious about the calls to swap your trans. the axle should pop right back in. this same exact question was posted yesterday? weird.
