90 Loyale Code 11
Out of interest in my Loyale's minor hesitation issue ( when warm, seems to run perfect for the first 2-3 min in the AM ), I observed the codes per the white connection procedure found in various threads. I get one long flash and one short flash, seems like 11. That is it. No CEL. Now, would that not indicate Cam Position Sensor issues? Interesting, because I thought this would mean no start. Hmm...car starts and runs decent. Changed o2 sensor, no effect seen.
I remember reading somewhere that crank angle codes can
show up if the car stalls. I had two of them and they went
away when I cleared the ECU. It could be an old code if
you've never cleared 'em.
SPFI or MPFI?????
IF SPFI, wires # 19 power (output) 20 signal (reference) 21 signal (position)
code 11 = crank angle sensor (No reference pulse)
IF MPFI, wires # 7 (power) 8 (reference)
SPFI or MPFI?????
SPFI
