March 16, 200620 yr How much would you expect to pay for 2 front wheel bearings installed? Assume this is from a dealer whom you trust and know to do good work. I have a quote from my local dealer and I want to compare. Thanks, Reid
March 16, 200620 yr I would say around 300.00 for each side. If you take the spindle and hub off you can take it to a small shop and they will press them in for around 20.00 each. How much would you expect to pay for 2 front wheel bearings installed? Assume this is from a dealer whom you trust and know to do good work. I have a quote from my local dealer and I want to compare. Thanks, Reid
March 16, 200620 yr Author I'm sorry, this is for a 97 Legacy Outback. The bearings are $60 a piece from subarugenuineparts.com. How many hours of labor does this take? Reid
March 16, 200620 yr yeah bearings arent that much but you will need oil seals, a snap ring and axle nut too still... around $79'ish each side let me know if I can help you source some Jamie Thomas email: Jamie at chaplins.com http://www.subarugenuineparts.com *************************** http://www.subiegal.com
March 16, 200620 yr Damn that sounds like a good price! I have a 90 legacy and I called a parts store in town and they wanted something like 110 a piece. At the junkyard it was 18 bucks for the whole hub assembly. I went that route and swapped the hub assembly myself and saved a ton of money. Works great. I have no idea what the labor would cost you but I would imagine like 75 bucks an hour. (dealer)
