rotorque Posted April 9, 2006 Share Posted April 9, 2006 Just a quick wiring question, Does the ECU ground the pin for the main fan when the temperature reaches the set point or does it actualy feed power out of the ECU to ground? AND..... Regardless of how the feed comes/goes from this pin, is it powering a solenoid? Once again, any help here appreciated. Cheers Link to comment Share on other sites More sharing options...
Skip Posted April 9, 2006 Share Posted April 9, 2006 ROTO, sure would be EZ'r to answer if we knew which car's ECU you were askin' about - don't you think? Re gaurd less it is doubtful an ECU would power a rad fan directly, currents of this magnitude are handled by relays. 4 in stance, in the early model Legacy's, the ECU drops ground potential on the main fan's relay's coil via pin d17. This in turn turns the fan to turn. Hope this helps Link to comment Share on other sites More sharing options...
nipper Posted April 9, 2006 Share Posted April 9, 2006 In general the ECU (or any mystery box) powers nothing directly that has any real current draw. The ECU will provide a ground for a relay (sometimes relays are built into the mystery boxes) of some type. nipper Link to comment Share on other sites More sharing options...
rotorque Posted April 10, 2006 Author Share Posted April 10, 2006 Thanks guys, Just what I was after..... Cheers Link to comment Share on other sites More sharing options...
