April 10, 200619 yr my rear rotor is stuck on and their are 2 bolt holes to put a bolt in and press it off. what size/threads should i use.
April 10, 200619 yr the bolt that you take off to get the caliper up is the same size at least on mine.
April 11, 200619 yr You might also try loosening the parking brake adjuster. On the inside (back) side of the backing plate near the bottom there should be a rubber cover. Pull that off and with a flat blade screwdriver spin the gear looking thing up. ... You'll just need to re-adjust it when putting things back together..
April 11, 200619 yr Author the funny thing is, the e-brake don't work. i can pull the handle up and still spin the wheels
