May 6, 200619 yr Will parts from a 93-96 Impreza L Sedan fit on a 86 GL Turbo Wagon? Mainly just the Suspension parts and the parts for the 5 Lug swap...
May 6, 200619 yr not sure on that but i believe the only stuff that will work is off an xt-6 their are two in junk yards the one at co auto parts is in good shape i need parts off the other for a friend
May 6, 200619 yr front suspension use the xt6 lower control arms and tie rod ends. use the impreza axles, hubs, brakes, struts and what not.. the front strut tower bolts can be modified for impreza struts... just some grinding.. you may want to figure out something for an e-brake.. you will lose this when using impreza calipers.. rear suspesion you need the hub, rotor, and backing plate from a xt6 and your good.. rllywgn
May 6, 200619 yr Well Korean, in order to use the Impreza stuff in a EA82 car, here's the following link that I put together. It might be of some use. http://www.ultimatesubaru.org/forum/showthread.php?t=50400 It gives basically all the parts you're going to need from either an XT6 or an Impreza/Legacy car. If you need some help figuring out the parts, just gimme a shout either here or over on awdpirates. My '89 RX turbo has '95/'96 Impreza stuff in the front.
May 7, 200619 yr thanx all! If you need some parts, let me know since I got a '96 Impreza parts car that I'm trying to get rid of... plus I got a few other parts as well...
May 7, 200619 yr If you need some parts, let me know since I got a '96 Impreza parts car that I'm trying to get rid of... plus I got a few other parts as well... could you clarify how much of the GC8 impreza front end I need please- is it the whole thing or parts thereof? are these the same as a 96 legacy GT?
May 7, 200619 yr Its going to be just parts for the front end and yes, Legacy GT parts should work. You're ging to need... front knuckles front hubs/rotors front calipers front struts front axles front ball joints You'll need to get the control arms and the tie rod ends from a XT6, there's no other way around it. The rear you need XT6 parts since nothing else will work.
May 9, 200619 yr Can I use the front parts (-the controll arm and ball joint) From an 92 legacy turbo?? edit (Sorry didn't Notice the above post)
