paced Posted May 9, 2006 Share Posted May 9, 2006 I hear a loud squeak when moving slowly through rush hour traffic. It sounds like squeaky breaks but the breaks aren't being engaged. It is getting louder and it only seems to happen when the car is warm and traveling at less than 10 mph. Could it be the wheel bearing? The front breaks are new and the back breaks were replaced only 10k miles ago. Any ideas? Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted May 10, 2006 Share Posted May 10, 2006 likely it's a wheel bearing issue..... Jamie Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 10, 2006 Share Posted May 10, 2006 I hear a loud squeak when moving slowly through rush hour traffic. It sounds like squeaky breaks but the breaks aren't being engaged. It is getting louder and it only seems to happen when the car is warm and traveling at less than 10 mph. Could it be the wheel bearing? The front breaks are new and the back breaks were replaced only 10k miles ago. Any ideas? It ONLY happens when the car is moving forward? If you ever hear it when starting the engine, idling or reving the engine while staionary - could be a V belt. Carl Quote Link to comment Share on other sites More sharing options...
paced Posted May 20, 2006 Author Share Posted May 20, 2006 Had the wheel bearing checked out and everything looks ok. Yes, only hear the noise when the car is in motion. I think it might be a break issue becuase it only happens after the rotors warm up. Quote Link to comment Share on other sites More sharing options...
seanski06 Posted May 21, 2006 Share Posted May 21, 2006 my g/f's impreza does that too...usually she just pushes the brake in an then lets it out and it goes away....her brakes are always squeeky(cheap pads) and when shes going real slow u could hear them rub against the rotor Quote Link to comment Share on other sites More sharing options...
Suzam Posted May 21, 2006 Share Posted May 21, 2006 Could be the worn pad warning tabs are misaligned and dragging on the rotor, or a loose shim behind the pad. Does the noise stop when the brakes are applied? Hard to diagnosis noises on the internet. Quote Link to comment Share on other sites More sharing options...
JPX Posted May 21, 2006 Share Posted May 21, 2006 Have plastic wheel covers? Take it off and stick it back on. I've found if they are stuck on like they weren't tapped evenly onto the wheel, they can make a funny squeaky sound when rolling. Quote Link to comment Share on other sites More sharing options...
