Cooling Fan
why would you ask that?
my 4wd only has an electric so i'm thinking no...
My JDM EA71 (1600) came with a clutch fan on the water pump. My wagon was already rigged with an electric fan (real common) on the passenger side of the radiator. Helped big with cooling, but I took the clutch fan off and I got a buttload of hill climbing low end torque. If the thermo switch turns the fan on when it should, cool. If it don't, the mechanical fan is handy, but, replace the thermo switch so you can place the power your right foot demands to the pavement.
