SUBARU3 Posted June 11, 2006 Share Posted June 11, 2006 I have a valve lifter sticking, but it only makes noise when the engine is completely warmed up. Never when cold. The noise is not bad, just noticeable. I thought lifters made nose when cold and then quieted as the engine warmed up? The noise is only at idle too, a little gas and all is quiet. (I'm sure the oil pressure picks up) Mileage is 55K Mobil #1 10W30 Thoughts? Thanks, Todd Quote Link to comment Share on other sites More sharing options...
JPX Posted June 11, 2006 Share Posted June 11, 2006 Maybe take a read through this thread http://www.ultimatesubaru.org/forum/showthread.php?t=58174. It might be one of these guys (HLA) dying on you: If it is - all you need is a 10mm to get the valve covers off and feel around for the lazy hydraulic lash adjuster (HLA). Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 11, 2006 Share Posted June 11, 2006 you're positive it's HLA noise and not something else...fuel injector? how long have you been running synthetic? if it's not horrible i'd probably run with clean synthetic and frequent oil changes for awhile and see how it gets. some ATF or seafoam may help if nothing else does. oil pump ever been resealed? that may or may not help. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted June 11, 2006 Share Posted June 11, 2006 Put a real oil pressure gauge on the engine and go from there. Dummy light comes on at between 3 and 5 PSI (rediculous at any speed other than idle and even then is lower than I prefer (10 @ idle). Are you losing any oil between changes? Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted June 11, 2006 Author Share Posted June 11, 2006 Thanks guys! Boy, it doesn't sound like that sound clip!! That's not a HLA in my opnion! My noise is subtle, only when hot and at idle and not loudl. I'll try the oil pressure gauge. Oh...no oil loss at all. Todd Quote Link to comment Share on other sites More sharing options...
