July 18, 200619 yr Need some quick answers. Looking at a 1980 hatch, build date of 6/80 is it single range 4wd? couldn't tell, sticker was missing. Pulled up only one click but car has tranny issues and wasn't sure if that was affecting it. E71/81? Looked at the valve cover and saw no sticker so I know its not a hydro but forgot to look at block. 5spd/4spd? Lady said it was 5? has a sparkly ball for shift knob, couldn't tell? tried gears but was told again that tranny was shot. Heres the issue. I'm pretty sure I'm buying no matter what, Less than 100.00 bucks . White 4wd hatch had no gl/dl designation so I'll assume dl. body in fair condition, little rust in the doors, interior filthy das has major crack,will definitely need new carpet. seats need covering. plain silver steelies. Glass is all good, rear qtr window may need new latch mechanism. front bumper bent and rear bumper missing a pad. headlights(single round) and bezels and taillights all good. Has slanted radio console! Over all I think its a score! Next questions? If it is a 5spd single range, will a 4spd D/R be a direct bolt in? i believe so?
July 18, 200619 yr Round headlights.... does it have rear defrost? If not, probably is a Standard. DL also came with round headlights. GL has square headlights. 10-1 odds its EA71 4spd single range unless there happened to be a swap.
July 19, 200619 yr Author sounds good, I'm gonna check on it again tonight. Called her up earlier $75.00:headbang:
