July 26, 200619 yr I purchased a used '03 outback wagon with a climate control system. I've noticed that, while switching through the different modes, when I get to the mode with the defroster the air conditioning comes on. Is this normal?
July 26, 200619 yr I purchased a used '03 outback wagon with a climate control system. I've noticed that, while switching through the different modes, when I get to the mode with the defroster the air conditioning comes on. Is this normal? Yes, works better as the air is dried by the AC.
July 26, 200619 yr Ya i couldnt understand that either in my Nissan Titan u put it in defrost and i see the ac light on and kept pressing it. Then i called nisan and got the same answer.
July 26, 200619 yr They been like that for years now, ever since cars got more air tight. i hate it when im stuck behind a truck and the defrosters are on, cant turn to recirc. nipper
July 26, 200619 yr ... and the defrosters are on, cant turn to recirc. When I switch to recirc in my 2002 Forester, I am (almost) sure that this is a manual operation, because I can hear and feel a flap(?) move behind the controls. If I'm correct, then this means that I can turn to recirc regardless of the heater settings.
July 26, 200619 yr When I switch to recirc in my 2002 Forester, I am (almost) sure that this is a manual operation, because I can hear and feel a flap(?) move behind the controls. If I'm correct, then this means that I can turn to recirc regardless of the heater settings. my 1997 cant, nor my 1998 nipper
July 26, 200619 yr My '96 is the same way. When you hit the defrost button the recirculate light goes out. I guess defrost is fresh air only. But you can turn up the heat on defrost and get warm (ambient) dry air blowing on the windows, very effective.
