97 OBS AET vibration when in gear
I have a 97 OBS with 193,000 miles on it. The AET fluid have been change every 60,000 miles by the local dealer, & it has recently start a car vibration when it is shifted into gear. Shifting is smooth, there is no hesitation or problems other than a noticable vibration,(items in the door storage area will rattle together, & a slightly noticable pull on the engine) when I shiftout of park into any gear. When the shifter is at p. or n, there is no vibration. My daughter is now driving the car while at college, so hopefully the car will not be subjected to high mileage use for the next year or so. Any thoughts or advice??
Thanks
my 4eat, 97 obs does that... along with alot of other roo's with the 4eat... i wouldn't worry about it, it's just trying to let you know it's alive ;)
oh yeah, college cars for some reason get alot more milage than others... or at least mine did/does :brow:
Thanks
should you really let your daughter dirve a car with a porn setting?:brow:
It can be as simple as a bad tranny mount, or a weak universal joint. i would suspect a tranny mount.
nipper
Tranny mount? Is this something that can easily be replace? Or is it reelly something that I should not worry about?
