subjfd Posted August 23, 2006 Share Posted August 23, 2006 Hi, I have a 93 Legacy wagon 2.2 4wd non turbo 5 speed When driving at low speeds, I hear squeaking from front driver's side that goes away when driving faster, and sometimes when I go over bumps, I hear a metal klunking sound. I just bought new brakes I am installing on Friday, so IO want to check other things. I was thinking wheel bearing, what do you think ? Thanks JF Quote Link to comment Share on other sites More sharing options...
Jeff88DL Posted August 23, 2006 Share Posted August 23, 2006 I'm having the same issue but on the passenger's side. Squeeking and scraping when I'm making a turn. It has been getting worse over the past week. I'm thinking wheel bearing. Quote Link to comment Share on other sites More sharing options...
Phizinza Posted August 24, 2006 Share Posted August 24, 2006 Is it a squeaking that gets faster with RPM, or faster with speed? If so this indercates a bearing noise, maybe wheel bearing. It's hard to diagnose squeaking and klunking over the internet. S I suggest when you have the wheel off that side, give everything a good shake, sometimes you'll find loose parts, fualty ball joints, or bad struts. But really, this should be in the New Gen section, not old gen. Quote Link to comment Share on other sites More sharing options...
