August 25, 200619 yr Hi, Does anyone have a exploded view of a 1993 Subaru Impreza front axel they could supply me with? Thank you very much for your help....
August 26, 200619 yr Hey K: You are actually on the wrong forum. A 93 Imprez is considered "New Gen", if you can believe that!?! What are you trying to figure out? Maybe someone here can help... good luck, John
August 26, 200619 yr Author Hey sorry for posting in the wrong area, I realized that after I posted. I am looking for a exploded view of the front axel in an attempt see where everthing goes cause my right front CV joint is making all kinds of noise and shaking all crazy when I turn the the left and it's getting worse. I have read what to do but I would like a picture to get an idea. Thanks for your time and patience.
August 26, 200619 yr You don't really need an exploded view of the axle.. You need to just pull the axle and replace it. Less work, less time, less heartache.
August 26, 200619 yr Do you have any boot rips and/or grease leaking out? Would probably be much easier to get a used one from a salvage yard if practicable. If something is worn out in your existing one, it may have taken other parts/races with it and to buy those parts individually could add up quickly. A lot of people like autozone and such rebuilt cv axles, and though they have a lifetime warranty they might not be as reliable over the long haul as OE or a used OE. You can get remans through Subaru dealer too.
