rear diff leak
so my car's been sitting for a month. I hope to start it tomorrow after putting in the radiator and setting the timing.. but there's a little puddle of gear oil under the rear differential. I'm aware that seals can shrink and leak a little when a car isn't used..
the leak is at the front of the diff where the case receives the input from the driveshaft. Might I expect this leak to go away when I drive the car regularly again? I have no problem with getting an open 3.7 diff and swapping my LSD pumpkin over, but i thought I'd ask if this is likely to be a permanent problem?
and yes I'll top it off before driving regardless :P
thanks
Andy, I have a FSM supp. that has the procedure for that, looks real easy, let me know if you need it. All you need is a new seal and a dial inch pounds torque wrench. This can be done in the car.
