September 5, 200619 yr I have a 1981 GL hatchback and wanted to know if the 2 front seats are interchangable from left to right or not. Thanks in advance! JM
September 5, 200619 yr I have a 1981 GL hatchback and wanted to know if the 2 front seats are interchangable from left to right or not. Thanks in advance! JM I ve put the passenger seat on the drivers side if that what your asking, you got to put:banana: the track from your old drivers seat on the passenger seat, but your lever will be on the right side of seat to tilt the seat back or forward..
September 6, 200619 yr Author I ve put the passenger seat on the drivers side if that what your asking, you got to put:banana: the track from your old drivers seat on the passenger seat, but your lever will be on the right side of seat to tilt the seat back or forward.. Thanks for the reply! Just to make sure I am reading you correctly, you mean that the tracks need to be switched as well as the seats because they are specific to each other? JM
September 18, 200619 yr Author Thanks for the reply! Just to make sure I am reading you correctly, you mean that the tracks need to be switched as well as the seats because they are specific to each other? JM Just as an update, these seats are NOT interchangeable. The back inside bolt hole is specific to the side that it is on. JM
September 18, 200619 yr its alright to leave only one bolt out. whats the worst that could happen? i used a pass. side seat in the drivers side of mine, just switched the tracks. the seatback lever is gonna gouge the heck out of your console tho. its worth it if you have a torn up drivers seat, but a good pass side spare seat
September 18, 200619 yr You can swap just the foam and cover easily. Just undo the hog-rings, and replace them with zip ties on the new seat's frame. GD
