msmithmmx Posted September 6, 2006 Share Posted September 6, 2006 I have a 98 Outback that I would like to put 6 disk changer with cassette from a 02-05 subaru. The 02-05 seem to have 2 plugs in the back. The big one seems to be standard but there is a samller white plug. Is this an AMP? Will this swap even work. Quote Link to comment Share on other sites More sharing options...
subeman90 Posted September 6, 2006 Share Posted September 6, 2006 as long as the radio you are buying is from a subaru that is newer than a 94 they are all cross compatable (ex. the new legacy because they are integrated) i have a 99 legacy that i put an 03-04 baja radio into it. Plug and play! You are talking about the integrated 6 disk with cassette right? If you are talking about "the add on" type then you need to make sure the reciever has the hookups in the back to run the external CD changer. Quote Link to comment Share on other sites More sharing options...
djmark7 Posted September 6, 2006 Share Posted September 6, 2006 should work, i put a 2002 cd changer in my 98 legacy no problem, just use the plug that fits Quote Link to comment Share on other sites More sharing options...
msmithmmx Posted September 6, 2006 Author Share Posted September 6, 2006 Subeman, That’s exactly what I am looking to do. Install integrated Subaru OEM 6-disk/cassette player from a newer Subaru. Quote Link to comment Share on other sites More sharing options...
89hatch Posted September 6, 2006 Share Posted September 6, 2006 Wow, great info that I didn't know. I was looking on ebay and saw those cd/cassette/weatherband radios from 98-99 Legacy/Outback. They have the same main connector, but also a smaller rectangle connector for something(Weatherband?). These may not be compatible or at least completely functioning with other models that don't have this other connector. Any ideas? I wouldn't mind putting one of those in my 95 Legacy. Thanks as long as the radio you are buying is from a subaru that is newer than a 94 they are all cross compatable (ex. the new legacy because they are integrated) i have a 99 legacy that i put an 03-04 baja radio into it. Plug and play! You are talking about the integrated 6 disk with cassette right? If you are talking about "the add on" type then you need to make sure the reciever has the hookups in the back to run the external CD changer. Quote Link to comment Share on other sites More sharing options...
ferret Posted September 6, 2006 Share Posted September 6, 2006 On the rear of current Subaru Radio's there may be up to 3 separate plugs. The standard Subaru 14 pin rectangular connector. The other 2 are for additional components. A rectangular 8 pin is for a sub-woofer and/or steering wheel controls. And the 13 pin din connector for external device inputs. The radios all will work fine with just the 14 pin connector plugged. Quote Link to comment Share on other sites More sharing options...
subeman90 Posted September 6, 2006 Share Posted September 6, 2006 Wow, great info that I didn't know. I was looking on ebay and saw those cd/cassette/weatherband radios from 98-99 Legacy/Outback. They have the same main connector, but also a smaller rectangle connector for something(Weatherband?). These may not be compatible or at least completely functioning with other models that don't have this other connector. Any ideas? I wouldn't mind putting one of those in my 95 Legacy. Thanks Yeah they will work in the 95. If ya want I have an 02 radio in my basement that we can "test" if you want to see for yourself. (it isn't forsale though) Let me know if you want to stop by some evening. Quote Link to comment Share on other sites More sharing options...
jamal Posted September 7, 2006 Share Posted September 7, 2006 http://forums.nasioc.com/forums/showthread.php?t=749402 I have an 05 6-disc changer sitting on my desk and I'm waiting for my David Carter reverse harness. Damn 1st gen legacies and their oddball connectors. Quote Link to comment Share on other sites More sharing options...
djmark7 Posted September 7, 2006 Share Posted September 7, 2006 i made my own reverse harness, hard part was getting the new plug, hadda go to a boneyard, but i did it Quote Link to comment Share on other sites More sharing options...
89hatch Posted September 7, 2006 Share Posted September 7, 2006 Great, thanks, I may take you up on that. i need to get the car back on the road. Having some trans issues that I'm getting worked out, but that's explained in another post:rolleyes: Yeah they will work in the 95. If ya want I have an 02 radio in my basement that we can "test" if you want to see for yourself. (it isn't forsale though) Let me know if you want to stop by some evening. Quote Link to comment Share on other sites More sharing options...
