October 6, 200619 yr I'm experiencing the condition described in this repair manual. Fan speeds 1 and 2 are non-functional, but 3 and 4 work just fine. It has great instructions for getting to the resistor block, but omits what should be done when one gets there. Could the author of this repair manual add the repair steps to the repair manual? Failing that, can anyone else fill in the missing steps? Thanks, BB
October 6, 200619 yr You just replace the whole block. Building your own block, while *possible* requires a lot more electronics skill than just aquireing a replacement. They are small parts, and usually only a few $$ at the yards. GD
October 7, 200619 yr Edrach was the one who had the parts and know how in a thread from long ago. Either PM him or he might respond here. Finding another resistor block in a JY car is hit and miss, they sometimes are just as messed up as yours.
October 7, 200619 yr I went on my own to fix it. If it fried once , it will do it again. This is my fix, you can risk it yourself if you really need it.It has been several weeks with it fixed , I leave it on one from the second the key gets turned on, etc. works like original http://93loyale.com/htrfan.html there are many combinations, if you cant use original resistance. the actual numbers for the resistors are in a post somewhere on the board. That would be my first attempt, if I did not splice what was left back together for original integrity (and then some).I would no doubt replace with a normal looking resistor setup given the oem numbers. finding an original, would be 12 years old, at thier newest. It is one of those pieces time can destroy, as much as use. time for some ingenuity.. I will post a fix given the numbers, to take out original wekaness entirely, as well as those coils getting tangled in things that would hurt them. (mine had hair in it)
