November 14, 200619 yr I have an 88 GL Wagon. The exterior door lock on the driver's side locks and unlocks the other door locks just fine. However, the interior door lock doesn't work the other locks. Any ideas on what is wrong and how to fix it?
November 14, 200619 yr Uh... The key is supposed to lock/unlock the other doors? Hm... My guess would be that something is worn. The interior panel comes off easily, and you can check out the mechanism. -=Russ=-
November 14, 200619 yr My 6 kinda did this at first, granted its a two door and only has to work one lock..... anyway I just had to clean up the mechanism to get it to work better.... or just jiggle the switch.
November 14, 200619 yr Lube - lots of lube. Get a can of white lithium spray grease and go to town on the pivots and actuators in the door - then spray the windows rails, hinges, etc, etc, etc. Just spray anything that moves on the whole car with that stuff. It's great and water repellant too! GD
November 14, 200619 yr Author Sounds like a good idea. I THINK it worked once, but I wasn't sure if I hallucinated it or not. I'll give it a whirl. I'll let you know how it goes. Thanks.
November 14, 200619 yr Mile also does this, or does not depending on how you look at it. I think the mechanisim is broke on mine, it just kinda flops around with no resistance on it. I'm more worried about the window switch bank, right rear goes down with drivers control, but you have to use the door switch to roll it back up.
November 14, 200619 yr mine did this too, just ended up being the switch that controlled the locks. I replaced it with one from the JY and worked great after that.
November 14, 200619 yr Author mine did this too, just ended up being the switch that controlled the locks. I replaced it with one from the JY and worked great after that. Hmm, so perhaps a switch replacement then. I can live with that, thanks.
November 14, 200619 yr Author Mile also does this, or does not depending on how you look at it. I think the mechanisim is broke on mine, it just kinda flops around with no resistance on it. I'm more worried about the window switch bank, right rear goes down with drivers control, but you have to use the door switch to roll it back up. Mine seems to have resistance, a bit more than it probably should in fact. Hopefully that means GD is on the right track. If it is broke though, I can live with finding a replacement switch.
November 14, 200619 yr I recently dealt with this problem on a 90 legacy and I am pretty sure that the basics are the same. There is a link rod running from the lock cylinder down to the lock mechanism and switch, and another rod running from the interior door handle to the mechanism/switch. The door handle's rod is probably bent a little wrong, so that it can activate the locking mechanism but not the switch contacts.
November 14, 200619 yr Author I recently dealt with this problem on a 90 legacy and I am pretty sure that the basics are the same. There is a link rod running from the lock cylinder down to the lock mechanism and switch, and another rod running from the interior door handle to the mechanism/switch. The door handle's rod is probably bent a little wrong, so that it can activate the locking mechanism but not the switch contacts. That sounds like a likely possibility. I will check it out while I am in there coating everything with white lithium.
November 14, 200619 yr you might want to try spraying some evaporating cleaner or solution in there, BEFORE the lithium grease... its always fun working inside a door. Whatever you can accomplish, can only help. have fun!
November 15, 200619 yr Author Good idea about running some cleaner through there first, will do. As a test, earlier today I fiddled with the inner lock a bit and given the slightly higher than normal resistance on the switch I decided to close it with a bit of gusto instead of carefully closing it. All the internal locks snapped shut. I think when I get inside the door this weekend and clean it all out and lube the bejeezus out of everything that this will clear my lock issues up. Thanks again for the good info and ideas, I will post back with and update after I have a chance to try this.
November 15, 200619 yr once it started to become apparent that you probalb yjust needed to press harder, i realized I kinda have the same problem, I think.. and to me, it has always felt like there was a good chance one of the long metal arms was a bit bent, or fatigued.. or something worn, in some sense.. more than a simple lube. So, my point it, you may need to swap something to really "fix" this, even if lubing it up makes it OK. It may just be OK for now, you know? just food for thought. Good luck, though.. I will be paying attention. I haven't bothered because MY car isnt anywhere near as bad as yours, yet, and the passenger's side is worse than drivers..
November 17, 200619 yr Author once it started to become apparent that you probalb yjust needed to press harder, i realized I kinda have the same problem, I think.. and to me, it has always felt like there was a good chance one of the long metal arms was a bit bent, or fatigued.. or something worn, in some sense.. more than a simple lube. So, my point it, you may need to swap something to really "fix" this, even if lubing it up makes it OK. It may just be OK for now, you know? just food for thought. Good luck, though.. I will be paying attention. I haven't bothered because MY car isnt anywhere near as bad as yours, yet, and the passenger's side is worse than drivers.. Yeah, I was thinking I would inspect everything carefully. I have some metalworking skill so if it is a bent rod or somesuch I can probably fix it or make another. Jason
