December 2, 200619 yr Where is the pcv valve on a 2003 Outback Wagon, 4 cyl, automatic? There doesn't seem to be one. I took off the air cleaner box to change the spark plugs and still couldn't find it.
December 2, 200619 yr Should be on the passenger side of the intake manifold. Very close to the throttle body. Should see a nice fat hose going onto a piece with threads sticking out of the intake manifold. They are kind of hard to spot for the first time, look for the fat hose.
December 2, 200619 yr Hi, not 100% sure about an '03, but here's where it is on my '96 and '00; it's a screw/thread in type, not just a 'pop in' like a lot of domestics.
December 2, 200619 yr Nice picture...Follow that same hose down to the rear motor block. Starting in 2002, on the USDM 2.5L, the PCV was placed on the other end of that hose, now screwing down into the block, just above the oil separator plate. Also note it is a different p/n since it now controls crankcase ventilation from the threaded to the hose side. Older Subaru's, even my older EA16, EA18 and EJ22's, were in the intake manifold and flow was from the hose side to the threaded side. As far as I have found, the newer ones are dealer only. If you use an older one on the newer motors, the check valve will close and there will be no ventilation and lots of blow-by. Also If I remember, they both have different thread sizes to prevent using the wrong one.
December 2, 200619 yr Wow, good to know. Hmmph, Subaru actually changed something... I'm pretty sure its the same PCV valve for all Subarus up to this change.
December 2, 200619 yr Wow, good to know. Hmmph, Subaru actually changed something... I'm pretty sure its the same PCV valve for all Subarus up to this change. It is, my dealer told me that the one I bought for my 84 is the same PCV valve they use until 2002.
December 3, 200619 yr I don't mean to jack your thread but I have to ask. Does my 2004 WRX have a replaceable PCV valve. I went to my local dealership parts counter and they said that my model year does not have one. I have not researched it further so I haven't found anyone saying anything different. I am just not quite sure they were looking things up correctly. Thank you.
December 3, 200619 yr Hi, not 100% sure about an '03, but here's where it is on my '96 and '00; it's a screw/thread in type, not just a 'pop in' like a lot of domestics. is there suppost to be a butterfly clip around the pcv? mine doesnt, it just goes on loose, lol, umm, is that bad?
December 3, 200619 yr is there suppost to be a butterfly clip around the pcv?Probably yes, but it probably isn't really needed; I mean it's not a ton of pressure there or anything and the hoses themselves are somewhat rigid. If you look at the 'pop in' types (rather than screw in) they just slip into this rubber/plastic holder and do alright that way.
December 3, 200619 yr I don't mean to jack your thread but I have to ask. Does my 2004 WRX have a replaceable PCV valve. I went to my local dealership parts counter and they said that my model year does not have one. I have not researched it further so I haven't found anyone saying anything different. I am just not quite sure they were looking things up correctly. Thank you. No PCV in the WRX...it has a solenoid to control the crankcase vent flow depending on vacuum or boost in the intake manifold. Many people put oil 'catch cans' on the turbos to catch any oil before it gets into the inter cooler and coat the inside effectively making it less efficient.
December 11, 200619 yr Author Well I changed the valve today and it is onthe lower/engine side of the hose. It's really easy to get to. My valve was badly gummed up and didn't rattle The dealer asked for the VIN number to be sure it was the right valve. They said they hardly go bad. But mine, after 85,000, needed changing or cleaning. I decided to replace. The replacement was about $21. We'll see how the car runs now.
December 11, 200619 yr [...]My valve was badly gummed up and didn't rattle [...]We'll see how the car runs now. Weren't you having some oil getting past seals? It might do less of that if pressure due to blow-by is lessened by functional PCV.
December 11, 200619 yr Author Weren't you having some oil getting past seals? It might do less of that if pressure due to blow-by is lessened by functional PCV. Yes, I had a small oil leak into the spark plug socket.
December 11, 200619 yr Hi, not 100% sure about an '03, but here's where it is on my '96 and '00; it's a screw/thread in type, not just a 'pop in' like a lot of domestics. Can I ask: What is an IAC? And what is that foam thingy located in the middle of the Vacuum line? Thanks!
December 11, 200619 yr IAC Idle Air Control. That which under control of the ECU, opens and closes an air bypass passage to maintain a set idle speed. Small foamy thing is a One way vacuum valve.
