Oil pump seals
Does anyone have a step by step for changing these. I have them now I just need to replace them. Thanks
Nate
I can copy the pages from the service manual if you want - that's a good start. There are a lot of people who will probably give MUCH better tricks of the procedure than the manual, tho.
I'm all ears.
Need to do one of these my self as soon as I can get the parts!!
It'll be the first one for me.
Stumpy
There's no real tricks to it. You remove the timing belts, and take out the 4 or 5 10mm bolts that hold the pump to the block. There's two seals on the pump, you clean the mating surfaces and reinstall. Takes about the same time as any other timing belt removal type job (front main, water pump, cam seals, etc) - about 2 to 3 hours if you have the covers in place, and about 20 minutes if you don't.
