December 20, 200619 yr Anyone have it, every scan has the "refer to foldout" but nobody seems to have scanned the foldout.
December 21, 200619 yr Is this something that would be in a factory service manual set. I have a complete set for 90...I even have a 90 Legacy. I have no idea of a SMJ, either what or where it is. DAMFINO Richard
December 21, 200619 yr Author It is in a FSM a friend has my FSM, which happens to be one of those E-bay store copies that leaves out the foldouts so it probably won't have what i need anyway The 10 gajillion FSM scans on the internet also have all left out the SMJ fold out It would be near the front of your FSM book 6 if you have a "real" copy and if you find it would you be a dear and scan it and upload it?
December 21, 200619 yr Mine is a factory service manual for a 1990 Subaru. And it makes reference to a fold out....I don't see one anywhere in book 6. If you have the electrical schematics the pin out of all the connectors appear to be there. No idea why my book liste the foldout but does not have it. My books when purchased were clean and pure as if they had never been touched. Sorry I don't have a copy. Post a link to it if you find it please. Richard
December 21, 200619 yr sorry about the format...how do I attach an excel file? This is from the Subaru-vanagon list....trust it's all the same. You may be able to deciper the crap below. There are four columns by 16 rows for the 16 pin SMJ and 4 columns by 12 rows for the 12 pin SMJ. The four column headings from left to right are Computer Instrument side; Wire location; Engine side; and Color. Note that pins 6 and 8 on 16 pin SMJ and pin 8 on 12 pin SMJ have no wiring. -TG 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Ign relay#3 1 Injectors Y/R d6 2 CPC solen W/Bl Ign Relay #4 3 IAC +CPC Sole Y/R Ign. On 4 Injectors Y Ignitor 5 Coil R/G 6 Ignitor 7 Coil Lt Bl 8 d13 9 Injctr 1 Br d12 10 Injctr 2 Lt. G d11 11 Injctr 3 Lt. Bl/W d26 12 Injctr 4 Lt Bl d/24d25 13 Ground B/Y Ignitor 14 Ground B d14 15 Ground B/W a11/a22 16 Ground B/R 1 2 3 4 5 6 7 8 9 10 11 12 c6 1 Throt. Snsr Br b1 2 Throt. Snsr W b3 3 Throt. Snsr R b2 4 Throt. Snsr B a7 5 H20 Temp Sndr B/Y a21 6 H20 Temp Sndr R/G c11 7 Ground G/B 8 Oil Press Lt (.3bar) 9 Oil Prss Sndr G/W Temp Gauge 10 Eng Thermometer W/G d2 11 By-Pass Air Cont W d1 12 By-Pass Air Cont B
December 21, 200619 yr Author The SMJ is 6 columns by A-P rows, so its a 6X16 i'm specifically looking for the wires that go through L4 and L5
December 21, 200619 yr I've got the actual manuals. I'll try and take a look at them when I get home.
December 21, 200619 yr Why not just eliminate it? One at a time solder the wires from each side to the opposite side.
December 22, 200619 yr Author Umm, yeah, eliminateing it is easy, its the 2 wires that don't have a home that are currently the problem.
December 22, 200619 yr Noah, Shoot me a PM or email so I remember. I got tied up with other things last night and forgot.
March 13, 201115 yr Old thread I know. Does anyone have the fold out for the Legacy 66 pin SMJ? It would be nice to have.
March 13, 201115 yr Author should be one in the EJ swap writeup in the retrofit forum Writeup Edited March 13, 201115 yr by NoahDL88 ETA, I did your work for you.
March 13, 201115 yr I have read that and there is a picture of the connector but the "fold-out" that it refers to seems to be missing.
