deyoungc Posted January 8, 2007 Share Posted January 8, 2007 Yet another problem with my '99 OBW. Recently, when starting my car, I have noticed a strong smell of exhaust. I don't smell it while in the car with the windows up, but if I have the windows down and back up...I catch a whiff. In addition to the smell, I frequently, on cold morning where the vapor is visible I see a hint of blue in the exhuast fumes. This leads me to believe that it is burning oil somewhere??? About 10,000 miles ago I had a leak in the crankshaft case. I had the seal replaced and my timing belt as well as a few other things fixed at the same time to save on labor costs later. Does anyone see a connection to this and my above problem? I don't recall or know if I had stinky exhaust before the leak. Any ideas on what the issue may be? Quote Link to comment Share on other sites More sharing options...
sailhard Posted January 8, 2007 Share Posted January 8, 2007 Both my '96 and 2000 subies smell harsh at cold startup... almost like starting fluid or some damn thing...No idea but no problems either. Quote Link to comment Share on other sites More sharing options...
nipper Posted January 8, 2007 Share Posted January 8, 2007 Sounds like another oil leak. Get under the car when you first start it in the morning, you should be able to see smoke come off of where. Plan b is to clean the under carrige of the car, then the next day look for the leak. Thats the one problem with soobies. Any other car you have a leak your keeping the driveway fresh. Soobies it all ends up on the Y pipe. nipper Quote Link to comment Share on other sites More sharing options...
deyoungc Posted January 8, 2007 Author Share Posted January 8, 2007 I'll take a look when I first start it up in the morning...although it seems like the "smoke" is actually coming out of the exhaust pipe. Sounds like another oil leak. Get under the car when you first start it in the morning, you should be able to see smoke come off of where. Plan b is to clean the under carrige of the car, then the next day look for the leak. Thats the one problem with soobies. Any other car you have a leak your keeping the driveway fresh. Soobies it all ends up on the Y pipe. nipper Quote Link to comment Share on other sites More sharing options...
montana105 Posted January 9, 2007 Share Posted January 9, 2007 Can you describe the smell of the exhaust, does it smell gassy or like oil? The blue tinge does indicate oil burnage but I've noticed a slight tinge with my car at start up when cold and can not find any leaks or usage problems between oil changes. I'm wondering if the car is running rich on colder mornings in response to the computer ( like the old chokes of the past) to assist in cold startup? In warm weather I get no smells or tinges. John Quote Link to comment Share on other sites More sharing options...
Setright Posted January 10, 2007 Share Posted January 10, 2007 A healthy engine, with working catalysts will have a sweet smell at start-up. Quote Link to comment Share on other sites More sharing options...
sailhard Posted January 11, 2007 Share Posted January 11, 2007 The catalyst coming up to temp! Yeah, thats what mine mine be! Sort of sweet... Quote Link to comment Share on other sites More sharing options...
