Windsheild question???
I found a replacement windshield for my 80' brat at a local U-Pull it but I have never pulled out a windshield b4 or know how to replace one once I have removed it. Has anyone done this?
Use razor blades! DO not try to save the dried,old rubber. (Unless it's a replacement seal and fairly new) The glass is more valuable than the rubber at this point.
Cut straight down around the edge and then in between the glass and rubber. (all the way around) You know when you have cut enough, when the glass just lifts out.
Todd
Only thing I would add is go carefully around the corners.Take your time and don't press hard.Make several light cuts instead of pressing hard.
