BlueRu Posted February 9, 2007 Share Posted February 9, 2007 Please if someone has or knows where i can get shifter bushings for my brat, please advise!!!!! stick with rubber, or go to poly? Thanks -BlueRu:-\ Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 9, 2007 Share Posted February 9, 2007 I doubt you need bushings. You probably need to mod the roll-pin hole in the shift rod. Do a search for "4 speed slop". That should get you some applicable threads. GD Quote Link to comment Share on other sites More sharing options...
Skip Posted February 9, 2007 Share Posted February 9, 2007 What GD says plus while your down there nice time to fab up a short shift Quote Link to comment Share on other sites More sharing options...
BlueRu Posted February 9, 2007 Author Share Posted February 9, 2007 ill check out the 4-speed slop. the car does have 215k miles on it, im not sure how long the bushings last. THanks man Quote Link to comment Share on other sites More sharing options...
BlueRu Posted February 9, 2007 Author Share Posted February 9, 2007 will a short throw work in a brat? Is their a cheap but good brand to use. thanks Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted February 9, 2007 Share Posted February 9, 2007 will a short throw work in a brat? Is their a cheap but good brand to use. thanks Skips post showed how to modify your linkage to make a short throw. There isn't going to be anything aftermarket for it. Quote Link to comment Share on other sites More sharing options...
BlueRu Posted February 11, 2007 Author Share Posted February 11, 2007 WELL ODDLY ENOUGH, WHILE I WAS LOOKING AT THE BUSHINGS, I DECIDED TO REPLACE THE CLUTCH CABLE, AND NOW SHE GOES IN GEAR LIKE NEW!!! WELL ILL BE A GREASE MONKEYS UNCLE!!!!!! Quote Link to comment Share on other sites More sharing options...
